Rust spots on deck
bats
28 Oct 2010
First noticed this in Ireland about a month ago. Now encountered this in Devon. A light grey very fine dust has appeared on the deck and coachroof. This contains some iron or iron compound that reacts with salt water to produce pin-pricks of rust on these areas. The spots can easily be removed with Y10 but their appearance is annoying.
bats
28 Oct 2010
No ... and the spots cover most of the deck and superstructure, although less significant in density than the pic shows.
sailoppopotamus
7 Jan 2022
Athens, Greece
Perhaps you have been berthed next to some selfish idiot using an angle-grinder?
Or stupidly drilled out a few rivets out of your mast without realizing the implications this would have for your own deck. Ask me how I know, my boat is covered in similar rust stains :) As far as I know nothing can be done other than to wait for them to rust themselves into non-existence while periodically cleaning the stains with oxalic acid.
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
You can do something about them, but you probably won't like the solution. Y10 or oxalic acid will temporarily remove them, but they come back. A permanent way to get rid of them on non-textured gelcoat is to sand with minimum 1200 grit wet and dry and polish the shine back with Farecla polishing compound. Small areas can be polished by hand. Don't worry about sanding through gelcoat, you can't on flat areas with 1200 grit before you arm falls off in pain, but take care on external corners. The amount 1200 grit removes is tiny, but it's enough to take the small speck of metal away.
Textured gelcoat is more of a problem. You can sometimes scrape the metal speck away with the tip of a scalpel blade,
sailoppopotamus
7 Jan 2022
Athens, Greece
Oxalid acid often removes rust stains.
Available everywhere. Exspensive as boaty products, cheaper for household use - same stuff inside
It does, but if you have microscopic specks of iron/steel embedded into your deck, like I do, oxalic acid is only a temporary solution. You'll remove the stain and it will keep returning until there is nothing left to rust.
Hoolie
3 Mar 2005
Hants/Lozère
Hydrochloric is a much stronger acid than oxalic. Is there any reason why it can't be used on gelcoat? Well rinsed off after use of course
rogerthebodger
3 Nov 2001
I use it on any rust on my steel boat and it does not effect the epoxy paint the boat / deck the boat is painted with
chris-s
24 Apr 2019
Our last boat seemed to be blighted by little rust specs. As mentioned, repeated Y10 or oxalic until they are no more. Some of the larger specs may be able to pick out with a pointer scribe.
Poignard
23 Jul 2005
South London
I don't know if this would work but what about trying a powerful magnet to get the bits out?
I had a bit of metal extracted from my eye decades ago using a powerful magnet.
Rhylsailer99
19 Jun 2020
Once after foolishly sawing a chain on my deck I though I had wrecked the topsides. There was rust spots everywhere, but a few wash downs with a weak solution of oxalic acid and they soon vanish.
It might take a few times for them to rust into nothing.
bats
28 Oct 2010
I think I know the answer. I anchor a lot. The anchor chain is rusted around the 30m mark. The rust extends about 5m either side. The manual windlass probably throws off specks of rust and the wind spreads it around.
Solution - re-galvanising, although one company was reluctant to 'contaminate' their bath. New chain? There is a total of 60m of chain so, at 30m, end for ending is not going to help. Or keep getting exercise with cleaning the decks/cabin top?
