wanzap1
How simple or difficult (expensive) Is it to have running backstays switched out on a fractional rig?
From what I've seen running back stays are normal on a fractional rig, I assume there is a reason for that.
Quite correct, and sweep them back enough one doesn't even need a backstayOnce again a load of rubbish. You clearly have not looked at fractional rigs so have no idea how they work. Suggest you read the earlier replies, particularly from William_H which will educate you.The vast majority of fractional rigs DO NOT USE running back stays. The most common arrangement is swept back spreaders to offset the forward pull of the foresails to avoid running backstays.
Some fractional rigs avoid using running backstays by having 'jumper' or 'diamond' stays on struts. The struts are at or near the hounds, angled forwards, with the stays running from the masthead to some point lower down. This can support the mast both fore and aft and sideways. A bit '1960s' perhaps, but still valid, and seen on dinghies in reverse, where the struts are angled back to resist the pull of a big kite.
There are rigs which have runners, but you only need to use them when sailing hard in waves, or if you want a tight forestay to get the jib shape right, without bending the mast too much. Or if you're setting a spinnaker in lots of wind.
There are other rigs where the runners are absolutely crucial.
To be honest, somebody proposing to remove running backstays based on the advice from a random person on the internet who has never seen the boat, and not consulting a rigger in their local area should probably not be too surprised if their mast later falls down...
Even if the random person is as sensible as Willam_H has proven himself to be over the years!
Consult a rigger.
Only after consulting a naval architect first for the righting moments, hull loads, etc. He in-turn might need to contact the spar manufacturer. Prob easier to just buy another boat!! In any event, fractional in-line setups had a fairly short life; it would be useful if the OP told us what the boat was.Consult a rigger.
Using jumper struts and stays not only stops/limits the leech tension bending the mast, but also transfers the backward pull of the permanent backstay to the hounds, so it reacts against the forestay.I don't understand. Jumper struts point diagonally forwards and stiffen the upper mast against backwards loads produced by the mainsail. Running back stays point diagonally backwards and stiffen the mast against forwards loads........
I'm not proposing to remove the running backstays based on advice on this forum. I asked if was a big task / expensive. Of course a rigger would be employed.
