ARE
There is a 3rd problem as well. When I bought the unit, I wasn't told that to connect the charger section of the Multiplus to the generator, I needed an extra generator control module. So when I switch my gennie on and I want to charge the batteries, I have to remember to switch on the original charger fitted to the boat.
That's not correct, A multiplus should work directly from the generator output, exactly the same as it should from the shore connection. I have a Multiplus in my motorhome and the only thing I need to adjust is the input limit from the shire line to maximum generator current. There can be some compatabilty issues between Multiplus's and different generator makes, but you can open up the parameters within the Victron to over come this.
Anthony
