Tranona
We motor at a sedate 6kts (2000-2200 rpm) - never said anything about hull speed (which is approx a bit over 8kts)
Darglow Featherstream (see #17)
OK. The revs you are using sound about right for that speed. Misinterpreted your comment about not using higher revs because of the effect on steering. yes, the Featherstream can be adjusted in both forward or reverse, but if Darglow set it according to the boat data you gave them it should be right.
Out of interest did you have the same control issues with a fixed prop with this engine (assuming you have used one)?
