RIN
Same here. Autumn service, winterise, and leave well alone till the spring.
I've always been advised that getting an engine (particularly a turbo diesel) only partially up to temperature (and you'll never get a turbo diesel up to normal temperature without running it normally - ie cruising speed/revs/load) and then shutting it down is inadvisable.
I have never had much problem getting the engines pretty hot on the pontoon by running the engines in opposition at just under 1500 revs. They do a lot of work in opposition. I do put extra lines on though to spread the load on the pontoon
