Rudders on narrowboats
VicS
13 Jul 2002
As big as reasonably possible i would think. No problems with following seas!
S
Skyva_2
Guest
Low aspect ratio, should not touch if the boat takes the ground, if I recall correctly. But best to ask on a more specialised forum for narrowboats.
Tony Brooks would know - http://www.tb-training.co.uk/
G
Guest
Guest
Friend wants to make a new rudder for his narrowboat, any calculations etc or advise please?
This any good?
snowleopard
16 May 2001
Oxford
While going ahead you need only something to divert the prop wash (look at the sort of thing they have on seagoing mobos). When reversing however you need something a bit bigger, preferably partially balanced to stop it wanting to slam hard over. Some narrow boats are easy to steer in reverse and others are complete sods. Best try a few and see what works.
JamesFrance
24 Oct 2006
Sant Carles Marina, Spain and Carcassonne
You definitely need the skeg shown in the drawing above, as the canals are full of rubbish. It will also give support to the rudder in case the rudder catches on the lock sill when locking down. All too easy to bend the rudder post otherwise.
They are simply cut out of mild steel plate, say 10mm.
I wonder what happened to the old one?
