stormdancer
rudder problem update
Thanks to you all for relying, sorry for not giving you all the facts.
The boat is a Sunray 21 bilge keel yacht and yes it does have a small skeg, to which the rudder is housed in a bearing at the base and a tube running up through the hull and cockpit and yes there is some movement in the head if you push and pull the tiller. I can't recall seeing a grease packing device, I assume you mean like the type fitted to the prop shaft on internal engines.
I would be most grateful for any advice on how to change these bearings and the best type to buy, a blow by blow account of removal would be great.
I am a heating engineer so I am quite handy when it comes to diy, also would it be possible to undertake this task at low water as I have about 6 hours of dry time per day on my mooring or will it have to be lifted out.
Thanks once again for your help
kind regards
David
kind regards
David
