Lakesailor
I have discovered that whilst outboards are OK for small boats, close quarter manoeuvring without a rudder (always had them on yachts before) is a nightmare. As I like to put the boat into the boathouse stern-first this can be a balls-ache.
I had just built a clamp-on rudder which attaches to the outboard leg and has transformed the low-speed handling. As it's a displacement boat and can only manage 6 knots it doesn't have to be flip-up or anything posh.
Here's the story.
I made a cardboard template. It included the cavitation plate as I thought it may need to have little clamps on to that as well.
Then I bent some steel strip to the template and found a bit of grp, for the rudder blade, which I'd cut out of the boat's buoyancy tank to make a hatch.
I had some "D" section rubber fendering left from fitting to Feckless last year.
and squeezed that over the steel strip to protect the leg.
A test fitting seemed to look good
I cut the grp to suit (I hoped)
I used stainless bolts with locknuts. I know the clamps are steel, but it's only freshwater and I don't think it'll be a big problem If it is I'll do it in stainless or alloy.
There it is fitted
There is a little lip in the casting which I hope will locate it.
The proof of the pudding etc......
....is the video of before and after. In the first part you can see that getting lined up is tricky with any breeze blowing and the only way to steer is a small burst of throttle, which may get you travelling too quickly towards some very solid walls.
Any comments or suggestions welcome.
Here's the story.
There it is fitted
