Ian_Edwards
I have a Southerly 46RS which has a very deep high aspect ratio keel with a draft (keel down) of 3.3m, and very low aspect ration shallow twin rudders, which allow the boat to take the ground. The draft when the keel is up is only 0.8m and the rudders are less than 700mm long.
When the boat is reaching in gusty conditions it can be very difficult to control the boat, in essence the boat develops a lot of weather helm and the rudders stall.
When I eyeball the rudders they look like they are far from a NACA 0012 cross section, the leading edge looks far too blunt. The shape is driven by the large diameter rudder stock which is placed well forward, so although the rudders are semi balanced, the area forward of the stock is relatively small. This in turn leads to heavy steering loads when the boat is hard pressed.
I'm thinking of dropping both rudders this coming winter principly, because they both appear to have water in them, and getting them rebuilt. This presents an ideal opportunity to reprofile them. However, I'm struggling to find information on how to improve the performance of the rudders. I'd like to change the cross section to a NACA 0012 and add some area forward of the rudder stock. The objective is to reduce stalling, i.e. increase the angle at which they stall and to reduce the steering loads by moving the axis of rotation back from the leading edge.
So a request for pointers to the optimum design of low aspect ratio rudders (technical paper, books or articles) and possibly to someone who understands the design and advise on an optimum design.
