Wansworth
None of that it’s that is whatthe boat comes equipped with with,certainly to furl the jib in a second would be great but I am not keen on furling gear used as reefing ,but as you point out not intending to sail in anything above force 4…..but the engine is the make or break as trying to adjust the outboard in confined area and juggle the tiller could be a pain………there is an identical boat,more expensive with an inboard engine and furler…….lots to see,but old inboard could be a money eater?I doubt Wansie will go out in anything above a F4 so handling the sails will only require physical effort rather than working on a pitching foredeck. However it seems very much a masochistic and retrograde step to me probably based on a rose tinted memory of past times.
