Round Britain day 83
Concerto
16 Jul 2014
Pwllheli Marina, N Wales
Normal service resumed today. Full oil skins and boots with lots of wind, almost like sailing in the northern isles but with sunshine.
Low water at Strangford was a few minutes before 11 today, so that was my target time to leave the lough as I needed to be in Peel at high water +/-2 hours. Slipped the berth at Killyleagh at 9.55 and once clear of the moorings I raised a single reefed main and left a reef in the genoa. The forecast wind on several web sites suggested NNW 18 to 26 knots, so I felt I was being safe. Initially I was certainly undercanvased in the lough, but the tide made a big difference to speed over the ground. At exactly 11.00, I passed through the shore ends of the lough and it was virtually slack water.
As the tide was flooding southward, I set a course on th autopilot about 12 degrees above the direct course. The wind did increase compared to the lough and was on the beam, so I was sailing fast at about 6 to 6½ knots. After about 10 miles, the wind increased even more and I felt it would be better to hand steer. The boat speed was now in the 7 to 7½ knot range and needed a lot of concentration to hold a steady course as the waves were increasing and could turn the boat off course. It was great fun for half an hour, but realistically I was now over canvassed and needed to reef. I started by reefing the genoa to 2nd reef and then immediately dropped the second reef in the main. That was not that easy as I had to bring the boat round by 50 degrees to be able to get the mainsail in a position to pull it down at the mast. I always do this with my arms around the mast. Once settled back on course I returned to hand steering and Concerto was still making about 6 to 6½ knots, but much easier to control.
Later I was glad I had put the double reefs in as the wind increased further and the number of white caps had increased dramatically, leaving the spume in wind lanes. That means the wind was now a force 7 and some of the waves were over 2 metres peak to trough. The wind seemed to back slightly and was now about 20 to 30 degrees behind the beam, or the tide a was slackening and needed less course correction. Approaching Peel the sea looked rough and it was a lee shore as well. About a mile out I dropped the mainsail as I knew I would have to gybe to enter the harbour and gybing a genoa was a lot safer to do. It was so rough now I could not get any fenders and warps prepared. I contacted the marina on VHF and they opened the bridge ready for my entry.
In the final approach using the autopilot, I wanted to be close to the outer wall for calm water and reduced wind. However a wave took the stern and I very nearly hit the wall, only my quick reaction to hit standby and pull the tiller saved the day. The fishermen on the wall were none to pleased. Once sheltered I furled the genoa and started getting the fenders ready, but then I realised I was getting too close to the wall near the castle, but below the entry for the marina, even though I had not engaged the engine. All the fenders were ready but no warps. Turning into the approach for the bridge and into the marina, I was now "sailing" under sprayhood. Panic, there was not enough space to safely fit the warp. I managed to get the aft breast and spring rigged before I had to turn into make my final approach into a finger berth head to wind. Nothing I could do as the wind was whistling through all the masts. I decided a slow contact with the bow on the wood edge of the pontoon was necessary. Just as I lightly touch, the man from the marina appeared and held the bow steady whilst I fitted the aft spring and breast, then added the forward spring and breast. No apparent damage on the bow, just a minor mark. All tied up by 15.30 and having covered about 36 miles. It has remained windy and it is quite noisy with tapping halyards and wind whislting in the rigging, plus some movement within the berth and slight rolling at times.
The man from the marina advised I get a local pay as you go sim card for my phone as Isle of Man has international roaming charges of £2 per day plus charges for texts, phone calls and internet. So went for a walk to find a local store that sold them, the sim was free and I put on a £10 credit. This includes 500 minutes/texts and 10Gb of data, valid for 14 days . That will be more than enough for the 4 nights/5 days I am on the Isle of Man.
Good tidal push of nearly 4 knots past Portaferry
I cycled past Kilclief Castle a few days ago
Leaving the lough at slack water, with the photo taken at exactly 11.00
Just before I put the second reefs in
Peel Castle. the harbour entrance is off the left of the photo
It looks calmer than it was with the wind funneling along the marina
For anyone wanting to read the reports from the start, this is the link to first one.
Round Britian day 1
83 days in its truly remarkable. Can’t imagine how physically challenging it must be on one’s own. Not bad for a Fulmar either.
Steveeasy
Loving the daily blogs, and envious that you’ve been able to make the time for your adventure.
As I sail single-handed most of the time I keep lines rigged from the forward and aft cleats made off to the centre cleats, on which there is a short midships line. It means I don’t have to go any further forward than midships underway. All I have to do is put three fenders in place on each side and I’m ready for berthing wherever I’m directed.
Normally I rig fenders and lines about half a mile out, but yesterday would have been foolhardy to try in those conditions. On reflection I should have moved closer to the outer sea wall and finished rigging the lines before proceeding further, but I knew the bridge was being held open for me. What I did not know was the bridge was pedestrians only.
Today I visited several interesing places in Peel, and found there were no restrictions on flying a drone as I had previously been told it was not allowed.
Started with a walk towards the castle. Once I reached the castle I was shocked to see a barrier from a large concrete marker post to almost the entrance to approach the marina. Yesterday I must have been very close to it whilst rigging the fenders. Peel Castle certainly dominates the skyline, so I went and looked round. It is a vast area within the castle walls, but all the buildings are repaired or being repaired but none are habitable.
Then as the tide was almost at the level for the flap to drop, I knew the harbour master would be in the office so I could pay my fees. He also advised the best time to leave for Douglas tomorrow.
Close to the Harbour Office is a light yellow building which is the Leece Museum. This building used to be the old courthouse upstairs, with the basement used to hold criminals before being tried by the local judge. Anyone caught on a Thursday had to wait until Wednesday to be tried as that was the only day the judge was in the west of the island. The basement now houses a collection of motorbikes dating from 1928 until the curent times. Included is Slipper Sam, the works Triumph 750cc production racer that is the only motorbike to ever win 5 consectutive TT races from 1971 to 1975. Upstairs is a museum with more local connections. There is a fairly large display of marine items. Also an interesting range of items created by those interned in a camp on the island during WWI plus a collection of memorabilia of holidaying on the island and the local carnivals.
Later, I climbed up part way up Peel Hill and flew the drone to capture some shots of the harbour and castle. As I walked back I saw a small transport museum, which only opens at weekends, and claims to have the world's smallest production car ever made, the Peel 50 which was made locally. Across the road was a small railway display.
Peel P50 - Wikipedia
Peel harbour
This was the wall I could not see as it was submerged and I came very close to
Peel Marina looking towards the sea
Looking out from near the bridge at the entrance to the marina
Peel Castle
Watch tower with a hall within the castle walls
Drone view of part of the castle grounds
Balance of the castle grounds
Some of the older motorbikes in the Leece Museum
The more recent motorbikes
Part of the marine section of Leece Museum
The railway display close to the marina boatyard
My favourite technique for short space, is engine in reverse. The bow blows downwind but the engine pulls stern upwind. Judge the revs right and the boat stays almost stationary (unless a cross tide). Ideal for doing ropes and fenders as can take plenty of time, whilst watching and adjusting revs slightly if necessary. From photos, could have done that inside the lock gate to give plenty of time?
Interesting idea, but with a fairly strong prop wash to port, unlikely to stay stern to wind for long. Once inside the marina there was some space before the pontoons and it might have worked, but once passing the end of the pontoon rows there was definitely not enough room. The trouble was how strong the wind was blowing and how quickly things could have gone wrong. Looking back I should have taken a few minutes longer behind the main sea wall to finish the preparations. It is always a learning curve when berthing in a stange marina in strong winds or tidal flows.
Chatting with the harbourmaster yesterday, I found I was the only boat to enter or leave the marina that day, which says something about the conditions. Yesterday there must have been at least 10 boat movements.
I think you probably did excellently.
“Get in, get a rope on, then sort the rest out “.
I grew up on long keel boats with often a quarter prop and underpowered in any sort of blow or strong tide ( but hey, little windage from high topsides ?)
Loving the bikes . Drool
Worth trying the engine in reverse trick. Prop wash tends to ease once been in reverse gear for a bit. And the more wind the more throttle, and can be more predictable as bow stays downwind.
Gives you time to think as well as to prepare. Took me years before I tried it, but now a complete convert.
