Seagreen
So, here's the problem.
Bought a venerable old boat, (about 140 years old- madness!) last May and though I had her surveyed, the surveyor could not check all the frames. The previous owner had completely retored the boat in the last 15-20 years, vouched the at all the suspect frames had been replaced or doubled, and then had "replaced the concrete and scrap ballast as found" back over the keelson.
So now the boat's ashore till april, with large refit TLC planned, I find the time to rip up all the boards and have a good poke around and find the nasty surprises...
...Which aren't huge but will be a problem. Two frames either side of the boat forward of the mast are gone competely where they enter the concrete, but are sound above. Two more frames on the Port side are a bit soft in the external timber. The heel of the mast is set up in another larger concrete block, though there is a galvanised frame between the two new ring frames that support the mast. I know the previous owner didn't salt through the hull (naughty) but I suspect that its really a reaction between
the timber and the concrete.
My normal response to this would be to remove the garboard and next planks up, and hammer out the concrete and re-frame. But if I was going to all that palaver, I'd reframe the lot and time and funds do not run to that at the moment.
There does not seem to be much movement in the heel of the mast, even when wanging through a 60degree arc in a heavy beam sea, the boat didn't take much water on, so I'm confident that the heel of the mast isn't moving much.
Back to the rot. The BIG IDEA, given that I don't want to rip out the garboards, etc., is that as a temporary measure, I will cut back to sound wood, and then removing all the rotten frame - the fastenings were all removed and replaced by copper 15 years ago- so leaving the frame "hole".
Plan is to scarfe in a piece into the good frame and filling the hole with part of the scarfe but the void filled with an epoxy plug. I'm planning to dry the hull out for a few months so that this won't cause adhesion problems, and drenching the area with a rot preventative weeks beforehand.
All advice gratefully received.
Mac /forums/images/graemlins/smile.gif
