kenhick
New Member
What would be the diameter of a anchor line to hold a 10 ton yacht I need to order 200 meters thanks
Surely it would make a big difference if the boat moves around and starts jerking at the lines?The displacement of the boat does not make a huge contribution to warp loading, it is far more dependent upon the area exposed to wind and waves. Guessing that the boat is about 37 ft in length, the rode loading in a big wind is given by ABYC as 1000 kg, although many authorities dispute this and quote around half that figure.
You may well find that rope of that strength is too thin to haul comfortably, in which case it makes sense to go up a size or two.
Use three-ply or better still multiplait rope which is stretchy and easily absorbs shock loads. That's why many people who anchor on chain will hook a short rope strop at the top end to take the load.Surely it would make a big difference if the boat moves around and starts jerking at the lines?
