A
Anonymous
Guest
I shan't be able to go to Seaworks in June. What did you learn after talking to the commercial vessel owners and operators?
So far over 4 years of supplying quicKutter and only two have needed any spares out of several hundred fitted, mostly to commercial vessels. Ferries, Pilot boats, Naval survey, RNLI, fishing boats. This is proof of robustness, as far as effectiveness recent articles in the fishing press interviewing commercial fishing boat operators have confirmed they work.
Unlike other systems the shaver cutter relies on debris being wound tight to cut it. If it isn't winding it is unlikely to get caught and do damage.
The recent test fixed one end of the debris to the bearing end, this meant that as it was drawn over teh disc or scissor it was fixed and not rotating with the shaft. In practice if debris is caught by the prop it will be rotating with the shaft, if this had been tested I would have expected completely different results and we would have taken part.
