bedouin
Not yetRats. Lakesailored.
The clues are in the report... Draft 4.5m, stranded yacht..... That suggests to me that the yacht was stuck in the putty, unable to reduce draft by raising the keel until they sorted the manual system. Once they’d done that the lifeboat escorted them to Ramsgate and assisted them onto a berth. Lifeboat probably tasked by CG in response to notification by yacht of a problem rather than crew requesting assistance. Took time to resolve problem, lifeboat stayed on scene in case things went horribly wrong.
Perfectly seamanlike approach to a situation.....
Edit.
Rats. Lakesailored.
Edit.
Rats. Lakesailored.
In a marine context, you and I take "stranded" to mean aground. Sadly, modern reporting has no knowledge of the meaning or derivation of words in the English language.
The boat was apparently 29 miles offshore.
Could still be aground. As I pointed out that part of the North Sea is riddled with sandbanks that could give problems with a boat of that draft. The emphasis in inability to raise the board suggests it was in shallow water and possibly in some danger - hence the call to the CG.
Neither the press article or the fb page make any reference to the lifeboat recovering them from being aground, it simply says it escorted them to sheltered waters off Ramsgate where further attempts were made to get the sail down (which the photos show was only around a third of mainsail out anyhow), and that they managed to get the keel up manually. Yes there are indeed shallow patches in those waters, but there are also plenty off deep water channels and there is no information to suggest any issues with steering or propulsion, indeed the photos quite clearly show the vessel under it's own steam with someone at the helm. I've not seen any information that would have suggested danger to either the vessel, it's crew, or others, it was simply yet another mechanical breakdown to which the lifeboat have been deployed by the Coastguard.Could still be aground. As I pointed out that part of the North Sea is riddled with sandbanks that could give problems with a boat of that draft. The emphasis in inability to raise the board suggests it was in shallow water and possibly in some danger - hence the call to the CG.
That's not me speculating, it's drawing logical conclusions from the facts they have supplied combined with a little knowledge (a little I stress) of the area and the options available, plus a look out the window at the prevailing weather conditions......
That’s what forums are for.Usual jumping to conclusions and criticising based on almost zero evidence of what actually happened.
Sorry it like Mumsnets with gossip and speculation
As Tr. stated before a yacht got into some trouble (no one knows) and called the CG and they asked the RNLI to go out . must be noted that the RNLI are volunteers and do not speculate , gossip , or criticise in any form on their rescues at sea, so that's a dead end , .
The RNLI are a public supported charity, it's not unreasonable for the use of those resources to be questioned and held accountable.
As for your dead end this is the reply I got on fb.
"We do not usually give many details regarding launches but we have decided on this occasion to give the facts regarding the decision to launch.
When the Coastguard set the pager off for a request to launch we phoned them for the reason of the request, they replied that the yacht had contacted them about 40 minutes previously reporting an electric problem and that they were not showing any navigational lights. Coastguard monitored them on radar in case any vessels appeared close to them, whilst monitoring the yacht it started to steer erratically so Coastguard tried to contact them via VHF, but could not make contact. Because of this and also because of busy shipping in the area they requested the AWB proceed to see if the yacht was ok, and We authorised the launch.
Hope this clarifies the situation."
Draw your own conclusion.
Speculation is valueless.
Fine to have a discussion, but best to base it on facts rather than speculation.
No it's not. Dutch summarised the value nicely in a post #15 above.
Depends why you're having the discussion, and what you hope to get out of it. An MAIB report based only on speculation would be useless, but for pondering and sharing ideas on what can go wrong, and how one could or should address it, speculation is just the ticket.
Exactly - anyone who thinks speculation is wrong or unhelpful on a forum hasn’t grasped what forums are most useful for
Most of the speculation here only exposes the writer's prejudices. That is why it is not helpful. Just look at the basic facts then read through what "speculations" and even "logical conclusions" people have just pulled out of thin air - or their prejudice (unsuitable boat, useless crew, should not have called the lifeboat, not in any danger, no shortage of water to sail in, only a mechanical breakdown etc.
How can anyone make such observations, and what purpose do they serve unless they just want to fill a vacuum. To move from the facts to these observations each one has made their own assumptions, and once you accept the assumptions then their "conclusions" might become logical. However it only holds if the assumptions are correct and as they are all made up in the writers mind they have no validity until they are tested against the facts - which are currently virtually unknown.
How can anyone make such observations, and what purpose do they serve unless they just want to fill a vacuum.....
They may serve to further a particular point of view. In my case I hold the view that a significant number of sailors are poorly equipped to deal with even small issues whilst at sea and and quite prepared to rely on an emergency service to resolve them. I think that is fundamentally wrong and undermines both sailing and the emergency services.
Stories such as this if left unchallenged may further that view, because there was nothing in the initial report that suggested it was anything other than a mechanical issue that could be resolved without placing the vessel or crew in danger, and it certainly resulted in a very protracted deployment from a large expensive lifeboat. Even the RNLI questioned the initial request to deploy, and despite their best attempts to subsequently justify why they did go I'm not convinced it was necessary. That's OK because as someone pointed out I'm just a busy body who shouldn't be poking their nose in, and if the RNLI want to become a publicly funded breakdown service who am I to interfere.....
The RNLI are currently a very well supported charity because the vast majority still believe that what they do is courageous and saves lives. I absolutely agree with that view and long may it continue. Anything that has the potential to sway public opinion away from that view should in my opinion be questioned and discussed, which I thought is what we were doing here.
What you sem to be doing is using this incident as a vehicle for your prejudice without knowing all the facts.
That is exactly the point I am trying to make. You have decided already that this is a "breakdown" event and does not justify the RNLI attending then you make things up to suit your beliefs. Then you even claim that the RNLI are "covering up" when they have already explained why the decision was made to launch.
Where do you get the idea that public opinion is being swayed against the RNLI? The very opposite seems to be the case, given the popularity of their programmes on prime time TV and the ever increasing level of donations. The only negatives seem to be some people on here who are always carping about what they do and questioning their decision making - just are you are doing now with absolutely no justification.
