Ring solar panel trickle charger
coromar
15 Dec 2004
I am thinking of buying a Ring 10w solar panel to keep my boat battery topped up. If we have sunny weather and the battery has a good charge (after a long run) is the solar panel likely to over charge the battery?
I see some larger panels have a charging regulator. Would I need one?
thank you in advance for your help.
Paul
Assassin
23 Jun 2010
In a nutshell they dont work as they are too small and if you put them inside a window the UV coating prevents them working as they rely on UV to work.
These were marketed as car battery chargers/maintainers and at 10W they didn't even overcome the batteries resistance.
Better options exist and the 100W solar panels with charge controller are available for around £80 and in best conditions they throw out around 4-5 amps.
PaulRainbow
16 May 2016
Suffolk
Paul
What battery ?
Refueler
13 Sep 2008
Far away from hooray henrys
You can connect a 10W panel to that without a controller. I won't add much (if any) charge to it, but it should keep up with natural losses.
I have a plain 10W panel trickle charges a 90 A/hr battery in my speedboat .... no controller.
Previously it maintained a 7 A/hr SLA House Alarm battery - to power the auto bilge pump ... then I fitted nav lights - planned a radio / music etc (still to fit) - so swapped to the decent sized car battery which had come out of one of my cars ...
10W certainly works for me .. its slow of course ... doesn't get fully charged ... but its good enough to be a viable setup.
