rigging cutters
Phildorset
10 Nov 2005
Poole
has anyone any recommendations? I need to get myself a set of cutters for that worst case scenario event... I think my Dyform rigging is either 6 or 8mm dia (I'll check of course). Thanks for any help choosing.
Get the best you can. I had to try cutting free a dismasted rig, the bolt croppers I had weren't up to it.
Speak to riggers, maybe buy a length of old shroud and test with that.
Also worth having pulling pins as an option, much easier than using cutters.
Having heard the horror stories about trying to do it with bolt cutters, I've been toying with the idea of carrying a cordless angle grinder.
Awaiting test report on how well the angle grinder works after brief submersion in seawater. Which should simulate the conditions in which it will be needed fairly accurately.
Felco C16
Good as it gets :cool:
We use this cutter, fraction of the cost of most and cuts up to 8mm Stainless.
http://www.bainbridgemarine.com/Item.aspx?Item=PRD-902217&PartNo=P63579
Think they may do 2 sizes, the ones we purchased are about a metre long.
Thanks for that prompt. I shall contact Bainbridge.
Then I can replace the huge, heavy bolt-croppers which I have carried around (getting rusty) for eight years while assuming they would perform OK. Apparently I have been under an illusion!
I use Bolt cutters to cut tensile and mild reinforcing bar in concrete, ( I have worn out my 3 foot pair) they will not cut wire they will just squash it, BUT they will happily chop through the solid threaded sections going into the bottle screws depending on their size and the brute force you can apply to them.
Personally I carry a hacksaw and some decent blades, again i would attck the solid sections not the wire I have assumed it will be during lousy weather and the deck heeled.
The Bainbridge ones look good value - anyone any experience of actually using them?
Might be OK. Over the years back in the day I must have cut tens of thousands of bits of 6 & 8mm SWR doing theatre installs, can't remember the brands of the cheaper ones but they wouldn't last long in real use, few days and you'd be swearing at them, felcos are the only ones that last. But for something that you'll hopefully rarely use for maintenance and hopefully never in anger they jaws could be OK for years & they might be fine. Be worth considering going up to 60Cm for 8mm stainless. Felco C16's are about 55cm.
We have used them for about a year now cutting stainless 1 x 19 wires from 6 to 8mm, not as good as Felco which we use for wires up to 10mm however if only used in an emergency and at a fraction of the cost they are good for keeping on board.
:encouragement:
I also carry a hacksaw and a box of good blades.
I am doubtful whether a hacksaw would work. In the process of collecting a recently acquired Flying Fifteen, I had to cut through a redundant s/s wire safety strap on the trailer. which was thinner than rigging wire. It took ages, far more difficult than cutting through a shackle or padlock.
Yes, I accept wire is a bit of a pig to cut, but as posted somewhere above, the shackles are a better target, and tend to be at deck level.
I also accept that we don't live in a perfect world and in the dreadful scenario of a dismasting all sorts of other things will conspire to spoil the hoped-for straight-forward wielding of the hack-saw!!
