Daydream believer
Is it really the actual tension %, or the relationship between each shroud,(particularly on factional rigs) & repeatability throughout the life of the rigging that matters?The full description of how to do this is explained clearly in Selden'a Hints and Advice document which you can download free from their website. It actually describes the whole process of setting up your rig from scratch using their folding rule method which is based on the Youngs Modulus of the wire to achieve a fixed percentage of UTS, regardless of diameter. They call it the folding rule method, because that's what they use rather than a tae measure and it's actually more accurate than most gauges. You do need a vernier gauge to measure the extension you achieve as well as the folding rule. I actually find a metre long dowel easier for the job than the folding rule, simply because it doesn't fold at inconvenient times.
Link to the Selden document:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwi6guHK3MiKAxUdzQIHHVlJHT0QFnoECBUQAQ&url=https://support.seldenmast.com/files/595-540-E.pdf&usg=AOvVaw1QvcnmY8kOsqoByMsQNFx5&opi=89978449
Peter.
