bozlite
Good afternoon, everyone. Hope somebody might be able to help.
Below is a picture of what I have recently discovered is an Albright SW202 reversing contactor, which is supposed to operate my bow thruster. It seems to have failed, however.
I hope it's possible to see enough of the the wiring to make sense of it. The main input is attached to the stud at bottom left, this is linked to the stud above it by a copper strip. There's a connection on the upper stud (thin red wire) which terminates in the choc box (why?). The studs at the left rear of the unit (top and bottom) are bolted to the motor casing. On the right hand side, there's a black wire which goes from a spade connection on the rear of the unit to what looks like a grounding stud on the motor casing. At the front of the unit, one black wire connects top to bottom, and a black wire from top and bottom return down the boat via the choc box.
The bow thruster is a 24 volt one, although the boat is mainly 12 volt, so this adds an additional bit of complexity. The 24v is created by a widget which temporarily puts the dedicated bow thruster battery in series with the domestic bank. I'm assuming this is working as expected because, on the contactor, when I put a voltmeter across from the input stud to one of the spade connectors I'm getting 12v constantly, but 24v when the bow thruster control is operated. However, no response from the contactor. What tests could I do to confirm that the contactor has failed? Also, is it possible that in fact the error lies elsewhere (I'm assuming not because I'm getting 24v, but it's probably a lot more complicated than that!)
Anyway, if it helps anyone help me, below is the picture of the wiring diagram left to me by the previous owner of the boat which explains the elaborate relay system. Is there anything there that looks like a likely failure point?
If anyone has read this far, thank you so much for your patience! If anyone can additionally point me in the direction of some tests I could do, I would be most grateful.
