Irish Rover
I rarely run the engines above 1,400 rpm and I generally rev them hard a couple of times before I turn them off to expel any accumulated soot. A few days ago I did this and I heard a different sound from one of the engines - somewhat like the sound you might expect from one of those manual trump fog horns. I immediately noticed there was little or no water outflow from the exhaust. I switched it off and checked the engine temperature which was normal. I closed the seacock and took the top off the raw water filter to see if there was anything obvious there. As soon as I loosened the cap all the water was sucked out of the filter. I left the filter cap open and opened the seacock. I was expecting it to fill up and overflow but nothing happened. I started the engine again and this time there was water coming out of the exhaust but not as strong a flow as usual.
There's construction going on at the marina and I often see bits of plastic wrapping in the water. I'm thinking I may have picked up something like that and it got sucked into the raw water intake when I revved the engine. The marina water is just too dirty to get into, so I'm planning to take the boat to a local bay where I can anchor in shallow water and get under for a look. I won't be able to do it until later in the week unfortunately so in the meantime if anyone has words of wisdom to share I'd be grateful to hear.
PS - I've put up around 100 hours since the last service and while we didn't change the impeller the mechanic checked it and said it was pristine.
