lumphammer
I would like to replace the seals on the windows of my 1979 Moody 36. The window frame has two outside sections screwed to an internal extrusion with self tapping screws every three inches or so from the outside.
I assume if I remove the screws I can ease the outer frames off. Presumably I should then be able to remove the 'glass' to get access to the seal.
Is it likely that the seals holding the glass in place are molded or could I refit with suitable neoprene rubber strips and quantities of silicon sealant?
