Replacing Cooker Gas Hose
emandvee44
29 Nov 2008
I took the cooker hose off as it is 6 years old and is slightly kinked anyway. I am confident that I can replace the hose and make leak tests.
How do I order a replacement?
It is 80cm long.
When I look on line, eg in ASAP supplies, it shows a hose with the spigots but without the nut and olive. Also the size is 8mm but UK suppliers quote 5/16".
Any advice please.
Cheers,
Michael.
8m/m & 5/16 are the same really size .
the new one will not have the nut & olive as the original . because once the nut is tightened it then becomes "captive" due to the compressed olive.
you do not these days need to have so called armoured flexible hoses, as these are std pipes encased, one cant carry out a visual inspection of the pipe.
when ordering get new olives & reuse the old nuts
As sailorman says, the nut and olive are technically part of the compression fitting at each end, not the hose, although they become attached to the hose once it's fitted. You can either buy a couple of new olives and cut the spigots on the old pipe to release the nuts, or buy a cheap compression fitting, use the nuts and olives from it, and discard the fitting itself.
....and seriously consider using some gas leak detector spray or liquid after fitting to check the gas tighness of the joints
http://www.bes.co.uk/products/051.asp#11721
My boat is due for an insurance survey, this year.
One of the things one always gets caught out on is age of LPG hoses.
It used to be 5 years.
UKgov has reduced that to 2 years and the authoritative UL21 specification wants you to part with much money to get it. Gates infer 3 years for their HP LPG hose.
Just a note of warning...
Hoses have the manufacture date on them with nothing to tell WHEN they were fitted
If you remove the stainless cuff by filing or grinding, you will be able to pull the end fitting from the inner rubber tube.
You can then re-use the fittings with new pipe and jubilee clips, clips and 8mm tube from ASAP.
And leak test obviously.
Thanks everyone.
I am going to order a new hose and a leak detection kit (I know - soap and water is cheaper) , cut off the spigots from the old hose to recover the nuts, and go into the local market to buy the olives.
If I am still posting on here in a few weeks time you will know I have been successful:rolleyes:
Thank you,
Michael.
Thanks everyone.
Thank you,
Michael.
copper olives recommended for gas .... not brass ...... or the vegetable type :)
I figured that was why it was yellow, like pH paper. Otherwise, why is it better than washing-up liquid.
It doesn't seem to form bubbles, so I'm not sure what I was looking for. I guess that means the joints were all OK, but one was very loose until I remade it with a washer under the flange.
They say washing up liquid is corrosive.
I'd be looking for bubbles.
Yes, they do, don't they. I was actually looking for bubbles, having tested that the liquid didn't do anything spectacular in the presence of gas. However the film was so thin that I wasn't even sure if I had wet the fitting in some places. Most of the fittings are difficult to view directly, I spayed a lot of liquid onto my mirror :)
