sailorman
that wont please the retailer if he gets stuck with a roll of itOurs have the expiry date printed on, not manufacture date.
8m/m & 5/16 are the same really size .
the new one will not have the nut & olive as the original . because once the nut is tightened it then becomes "captive" due to the compressed olive.
you do not these days need to have so called armoured flexible hoses, as these are std pipes encased, one cant carry out a visual inspection of the pipe.
when ordering get new olives & reuse the old nuts
Oyster Yachts do not fit armoured hoses from newA cautionary note. Although a visual condition check can't be made, some cooker installation instructions such as our Neptune specify armoured hose so could be a problem in the event of insurance claim following a fire if non-armoured hoses are fitted.
Have you got any stats on fatalities due to diy compared to "professional" work carried ourHi, Reading this Forum thread straight after reading the
MAIB Report on the Windermere CO fatalities does make you wonder about where DIY should start and end on safety critical items? This quote from the report expresses the MAIB misgivings.
Do-it-yourself (DIY) work is very popular in the marine leisure sector and is seen as an enjoyable part of boat ownership. It also helps to reduce the costs of running and maintaining a boat.
Nonetheless, there are numerous systems on board boats that, regardless of a boat owner’s engineering and mechanical skills, should only be installed, maintained or modified by a qualified marine engineer. In such situations, marine engineers should also follow equipment manufacturers’ instructions and use the correct tools and materials. The financial cost of using marine engineers to complete safety-critical work is inevitably more expensive than the cost of ‘DIY’. However, where safety critical systems are concerned such expenditure should be factored in to the cost of boat ownership.
Just a thought
Just a thought
Stats
Again from the MAIB Report, but not cross referring DIY with professional fit out!
The BSS records data of CO related incidents concerning boats on inland waterways and also on coastal boats having similar characteristics to inland craft. Table 3 shows data for a 20 year period, up to February 2014, in which 30 boat related CO fatalities were recorded, the largest number of fatalities was caused by portable petrol generators.
Source of CO Fatalities
Portable petrol generator. 9
LPG Appliance. 8
Solid/multi fuel appliance. 6
Petrol outboard engine. 5
Oil fired(diesel) stove 1
Portable diesel generator 1
Table 3: BSS data – CO fatalities
To place that in some sort of perspective, Manufacturing Companies with thousands of employees can easily go 20 years without a single fatality. Though they tend to exclude employees in Company Cars involved in fatal crashes from such figures!
While 30/20 is 1.5 Fatalities per year over the many thousands of small boat owners in the UK. The report also makes it quite clear that working alarms might have saved the two from any amount of poor workmanship!
The workmanship failings that contributed to the Windermere fatalities were from a DIY owner who was a qualified plumber, but who failed to realise that copper pipe work and soldered joints OK for, say, Central heating, might not be appropriate for engine exhaust gas temperatures.
Cheers
However, I did once have a gas leak and I can tell you that your snout is very sensitive. Probably more so than the gas detector - which I have not got.
