Replacing a missing trim panel on a Prestige 34
P4Paul
25 Nov 2007
Body in Hampshire. Heart in Cornwall
As the title suggests, this post is about a Prestige 34 owned by a friend of mine and berthed in a marina on the Hamble.
About two months ago, some scroatbag decided that rather than pay for a new starboard 'A Pillar' trim panel, they would use a screwdriver (at least thats what the gel damage suggests) to lever off the one fitted to my friends boat and leave my friend with the issue of sorting out a replacement item.
(If you have just had someone replace this trim panel on your boat or know someone who has just had one fitted, I would love to find out who did the work and where they got the part from).
Having been in contact with the local dealers and discovered that the trim is unobtainable, my friend who knows my history/background asked if I could help him out by making a new panel.
So below are some photos as I thought you might be interested in how it went.
To start with:
The port side trim
The Starboard side after the scroatbag had visited, you can't make out the gel damage in the photo but there are chips in the gel where it looks like a screwdriver has been used to lever the trim off.
So I get to work and take some measurements and make some templates
and then head home to the garage to make up a buck out of some foam block. A buck is nothing more than the shape I want to end up with, which I will then use to take a lightweight (splash) mould from.
a bit of cutting and shaping
Some lightweight facing from woven fibreglass and polyester resin (polyester is much easier to sand than epoxy!)
Some lightweight backing to prevent the buck from pulling out of shape as the fibreglass facing cures
and I ended up with a buck which was close enough at this point to use to make a single use splash moulding
I forgot to take any photos of the lightweight splash mould (apologies!). But once the mould was released from the buck, I sanded down the moulding surface. Any low spots or pinholes on the surface of the buck will become high spots on the mould, so sometimes it is easier and quicker to rework the splash mould rather than make the buck 100% perfect.
While waiting for the mould to cure I mixed up some gelcoat to match the colour of the boat and then laid up up the actual panel. After 24 hours I popped out the panel which looked like this
you can see pencil marks circling a couple of blemishes which I repaired. I covered the repairs with sellotape to ensure the gel surface cures. Unlike resin, gelcoat does not surface cure when in contact with air. You can mix in styrene wax to the gel (which is then referred to as flow coat) and the wax floats to the surface and foams a barrier between the gel and the air, but, I don't like using wax for repairs on new panels as I believe it makes the repair noticeable in the longer term.
I gave the panel a final sand to straighten and smooth the edges and then went back to the Hamble to fit the end result to the boat.
Most importantly, my friend is happy with the end result, but understandable he remains well hacked off that he required the panel in the first place.
Just in-case the scroatbag who stole the original trim panel is reading this; hopefully this post goes to prove that there is no need what-so-ever to go and steal a replacement from another boat. :encouragement:
+1 Shame you had to do it.
Yep, I still find it hard to believe that someone would sink so low as to steal a trim panel.
What makes it worse is that it has to be either a boat owner who has nicked it or has inadvertently and innocently paid someone in the marine trade to do a job and ended up paying for a stolen panel.
Leaves a bad taste in my mouth either way.
Nice job Paul , if you're ever passing lymington there are a couple of jobs on our boat that need sorting ;) .
Happy Xmas to you & Kerry btw .
Excellent post, thanks. I can't be alone in finding grp generally a bit of a dark art, so step-by-step articles like this are very helpful to a dimbo like me.
Owner-on-owner boat theft is sickening though, I've suffered from it myself. Well done for sorting your mate out. Happy Christmas!
Hope business has been good in the run up to Christmas, I guess you will be glad of the break on xmas day.
Are you and Jo intending to go to LBS, be good to try and catch up if you are?
Have a great xmas and hope 2017 brings you all health and happiness.
Amazing what can be achieved when a pint of draft Peroni is on offer :)
Have a great Christmas and prosperous new year.
Brilliant job. Like the others, I find it incredible that such a thing would be stolen. There's must only be a handful of these boats in the UK.
Incidentally, how does your mate like the Prestige 34? Could be an option for me instead of a T34 (that seem to be a little elusive in my price range).
They both love it, he is well over 6ft and built like a brick out-house and I have never heard him moan about headroom or space, I guess the double door to the fore cabin helps.
Great job, well done. I'm really struggling to believe another P34 owner swiped it though. How is it attached? If just held on with mastic then maybe it had come loose and the very strong winds recently have forced it off?
It would be an impressive bit of wind to use a screwdriver to jemmy it off though, no?
PS how're you doing?
I would love to think it had blown away in the high winds but you could clearly see where something like a screwdriver has been used to lever the trim off the boat.
If you look at the fourth photo you will see that the aluminium extrusion which forms the A pillar has two serrated channels and the panel clips into those.
I also struggled to think that someone had nicked it but when I went and looked at the Gel damage, everything points to it being stolen as the only explanation.
I should have also said that the top edge was sealed by Sikaflex as you can see also in photo4. There are no marks on the deckhead or roof to suggest the panel had come loose and blown about until detaching.
I thought maybe it had been removed before to fix a leak, hence the jemmy marks, and may have been re-attached with the wrong type of mastic. I guess I just dont want to believe another boat owner swiped it.
Leg is good thanks, partial weight bearing as of yesterday.
I would call prestige and ask who else has been trying to order one ..... they deserve hanging to be honest
Apparently there had been an enquiry a few weeks before this one went missing but nothing was ordered as it is no longer available. My friend has contacted the police but understandably it isn't top of their list of things to sort out.
