Replacement knob for Hella cabin fan
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I seem to be missing the knob for 2 black Hella marine turbo fans as are found on many boats
Does anyone know where I might get a spare?
The shaft of the male part is 15mm. Would any knob with 15mm diameter thread work???
TS
rogerthebodger
3 Nov 2001
Is it the big knobs on the side.
812.dat
I do meen the adjusting knobs not the knob that does the adjusting.
Most electrical knobs have a 1/4 inch hole with a grub screw to lock the knob to the adjusting shaft
15mm die thread would be quite a big thread. I would also measure the thread pitch ass the thread could be non standard.
I would try hella for a replacement knobs.
tudorsailor
12 Jun 2005
London
Once you decide the sizes etc, check out ebay.
Not the knob that controls fan speed but the one on the side that you loosen to adjust tilt (and vibration) and tighten again
Hella don't seem to have spares.
I guess if it's an M15 I could embed a nut in a 3D printed knob. Just need to find a M15 nut!
rogerthebodger
3 Nov 2001
M15 is not a standard thread size. The closest standard is M16 or M14 but M16 is the most common size.
Do measure the thread pitch before going any further.
Tou could also look for a knurled knob in brass or stainless steel.
penberth3
9 Jun 2017
Probably a quick and inaccurate measurement, but no - I didn't think there was such a thing as M15.
chris-s
24 Apr 2019
If it’s a nut and you can 3D print it, include the thread in your model. I’ve printed threaded parts many times. With a good amount and of infill they can be pretty strong. And you could print several spares.
tudorsailor
12 Jun 2005
London
A friend in Greece has confirmed that the nut is 16mm with 1.5mm pitch. I am in London. Boat is in Greece. If I 3D print an M16 nut or knob, could someone kindly test it on a fan to see it it fits if I post it too them?
TS
penberth3
9 Jun 2017
TS
Wouldn't it be easier and quicker to order what you need off e-bay?
tudorsailor
12 Jun 2005
London
Maybe but...... None of the knobs on eBay have the wide base as the fan knob has. So I have designed and printed a test knob. I have ordered am M16 screw on eBay and wait to see how it fits. Oh and more satisfying to create the knob and print it - if it works
TudorSailor
tudorsailor
12 Jun 2005
London
It looks just the job. Is there a technical reason why the orientation of the flats on nut do not match the orientation of the plastic holder?
My instinct is that a parallel orientation would be stronger.
Richard
No reason for the orientation other than it snapped that way when I was designing it in Fusion360. Strength is not a factor here so I will probably leave it as it is.
I will now print it in ASA as that is more durable that PLA. I intended to glue in the nut but the fit is so tight that it is not necessary!
I printed the knob on my new-to-me baby Ultimaker2Go printer which I have modified/upgraded. So not only am I please the design works but pleased the printer performs too.
TudorSailor
