ghostlymoron
Has anyone used Rolls batteries. https://www.es-store.co.uk/product_..._desc=Rolls-Batteries&cat_id=154&show_menu=25
One last quote from Rod aka Maine Sail about AGM vs FLA batteries. Exactly to the main (no pun intended) point I've been trying to make.
While many folks do buy them for the right reasons, many don't. AGM's definitely have some great benefits but are expensive and are, as we've learned over the last 17+ years in the marine market place, arguably a bit less tolerant of abuse than deep cycle flooded batteries.
This is not really a cruising Forum so why don't you keep your opinions for the US Cruisers Forum?
Since you have never used AGMs your opinions are just that.
Yes I agree with everything MaineSail says - I've have already said that in my replies - but you are just picking sentences which suit your opinions.
I agree AGMs are "arguably a bit less tolerant of abuse than deep cycle flooded batteries." -but MaineSail also says its because most of them can't be equalised. Lifeline and Full River can be. The most important point he also makes is that not all AGMs are the same!!!!!
Any battery - especially sealed batteries - that can't be equalised should not be on a cruising boat.
I agree further "discussion" is pointless....I see no benefit in further discussion so you are very welcome to the last word, whatever that may be.
Bye.
A pity because a lot of people are following this thread - I do hope they all fully read the excellent article which you linked to, which I agree with in total.
My last quote is a simple repeat from that MainSail article which refutes MOST of your arguments:
FACT: All lead acid batteries sulfate regardless of AGM, GEL or Flooded.
FACT: All batteries require proper charging
FACT: PSOC use will shorten the life of all lead acid batteries not just AGM
NOT ALL AGMs ARE CREATED EQUAL. - is also one of the most important points to remember. Like leisure batteries some are starter only, some are deep cycle, but many cheaper ones are for Telecom and Solar standby - not built and designed for regularly falling off 2 metre waves, nor daily 50% deep discharges. These points are just something else for potential users to understand which hasn't been covered in this thread.
Cheap AGMs are just not worth buying.
That's you told skipmac![]()
You're only allowed to cut and paste google results about AGM's if your boat has some.
Hi Skipmac
Can I thank you for your contribution to this thread and apologise for the rudeness you have been subjected for daring to confront a view that you did not share. I hope you ignore the advice to feck off, many of us welcome intelligent debate particularly when it is backed up by information pulled from respected sources and find it more illuminating (and entertaining) than uncontested assertions. I certainly would not like to be associated with the AGM faction if they can only defend their position by abuse, but the thread has opened my mind on battery choice.
And if this is not a cruising forum what is it?
I went cheap!
My 4 Jeanneau originals lasted just over 2 years, so I was worried about frequent replacements. My 3 Hankooks at £55 each plus VAT but including delivery have almost matched them and are still looking great. The boat is left in the water without power over winter with an occasional charge every 4 weeks or so. It sits on 12.9 volts output between charges. I hope to get a few more years and will then buy some more at that price.View attachment 63214
Just understand that a leisure battery is actually a vehicle starting battery, possibly a slightly enhanced starting battery but not a true deep cycle
You mean to say they are not deep cycle, hybrid, marine batteries ?
irate:
