pandos
The main bulkheads have some water staining and various screw holes, marks etc. I intend to reface them by putting on 4mm. mahogany faced marine ply. (self adhesive veneers are not available over here.)
My preference would be to cut the ply at home apply varnish etc and then stick this new facing onto the already varnished bulkheads.
Question, should I use contact adhesive and thus render the entire operation instant without the need for pins etc. or......
I could use flooring adhesive which will stick anything to anything ( I have used it to stick stainless steel to mdf) and is repositionable but has very little grab and needs to be pressed into position consistently for about 20 minutes.
Has anyone tried this before, it seems too easy a solution to transform the appearance of the saloon so drastically,
Regards
Regards
