dedwards
We’ve discovered that our rudder stock is worn on one side by 2 to 3mm (its otherwise 60mm diameter solid aluminium) for the 3 inches where it’s been in contact with the lower rudder bearing. The boatyard have quoted to make a new one requiring breaking apart the rudder blade and a price tag the wrong side of 6k. I am wondering if there are any plausible cheaper alternatives.
For example, would it work to weld over it a new aluminium pipe with aluminium epoxy used to fill the worn area in between? We need a new bearing anyway so the extra diameter shouldn’t be an issue.
