Repairing a "plastic" dinghy
lydiamight
9 Feb 2004
North West Kent
I have been given a 10 foot "plastic"--not fibreglass--dinghy which will be used for fishing on a small lake. It has a 2 foot gash down one side, about 1-1/2 inches wide.
Can anyone reccomend how this might be repaired?
I had thought of buying a fibreglass repair kit but I am not sure how this would adhere to the plastic hull.
All suggestions would be welcomed.
Not the answer you want but it depends.....
What is the plastic?
If polypropylene fibreglass will not stick, polyethene much the same, PVC possible with a primer.
Best bet would be to get it welded up with a hot air weld gun, look up local plastic fabricators and they should be able to help. Would offer but Kent is south of the Watford Gap!
Stuart
Could be polypropylene like a kayak or perhaps ABS - like the Tehri boats - and can easily be welded. Use a heat gun with a Sealey plastic welding nozzle and the appropriate filler rods.
If it's a Bic the repair kit is about £40.
I know someone who claims to have repaired polypropylene with melted milk cartons. Using a blow torch!!
as others have said, plastic welding.....
given the size of the gash the alternative for small repairs isn't going to do it - standard hot melt glue gun. works well.
sikaflex or equivalent will bond, but again it's a large 'fill'.
from my kayaking days iirc a linear plastic can be heat welded but a cross linked one can not.
You may find it's linear as x linked is much tougher and I bounced off many a rock and down many a waterfall in a x llinked one.
It's not pretty but (I forget the name, a tape with a bitumen type coating ) can, at a pinch, be applied pitumen side in wet but best wipe with meths first. It's remarkably durable and still the first line of defence as an emergency glass kayak repair.
edit:
http://www.directa.co.uk/site/scripts/product_browse.php?product_id=1809&category_id=1129
we used to cut it in to smaller pieces ready for use.
It needs pressing down on the surface hard (a paddler crash helmet wroks a treat). A riverside repair to a 50 to 75 mm hole lasted a further couple of hours and then a 26 mile paddle the following day with no sign of deterioration.
