mogmog2
I've seen plenty of stuff on repairing stripped screw holes in GRP but wondered if there was anything else to do in repairing oversized rudder fastener holes?
I'm currently thinking of using epoxy with glass strands from from CSM or tape, cut up smallish.
My application is the lower rudder tube mounting bolts on a Centaur (the bolts are a bit loose and the holes may or may not be enlarged). Another application is a transom hung rudder on a friend's Vivacity. These have definitely enlarged quite badly.
Would I need a different approach where the holes are only slightly oversized to where they are significantly larger?
