Poignard
You can usually see itHow do you know which is the serated end until it has been punched out a few mm?
Given the size and it being aluminium a heatgun will have its work cut out; an oven on a low heat(100-120C) or if there are plastic components a dunk in boiling water will work better if you have a big enough saucepan/casserole.Would not a heat gun played onto the aluminium - not the pins- so that the heat expands the metal & breaks the joint.
That was specifically for a stainless fitting in an aluminium bracket that was fixed by typical seawater insoluble deposits. I am not sure that the problem in this case is the same but there is no harm in trying it. Pure aluminium is attacked by hydrochloric acid, fairly slowly, but the typical alloys used for marine fittings are almost resistant. A good rinse afterwards is recommended.Ah, found it;
"Yes, I suggested that HCl might be a far better chemical method than Coca Cola or other methods often suggested. The corrosion product is probably an insoluble carbonate that is readily dissolved in HCl. I have posted a pic several times showing an aluminium masthead antenna bracket with the stainless antenna base firmly stuck inside it. A few drops of acid released it in a couple of minutes."
