Removing skin fittings / through hull fittings
David2452
6 Jun 2001
London & Fambridge
How about a suitable wooden peg inserted in the hole, and a bimetal hole saw, like these: http://amzn.to/1i0kjsV
Or perhaps a pair of hole saws on an Oops Arbor: http://amzn.to/1oczQn2
As in my previous posts, I have used Oops arbors for quite some time (call them my contralube;) ) and find them invaluable for this and other operations like opening out holes for larger fittings, they have the advantage of allowing the correct hole saw material to be selected for the material being cut. That said, a wooden bung and accurate placement of the pilot would work just as well for your purpose.
David2452
6 Jun 2001
London & Fambridge
forelle541
12 Dec 2004
Ipswich
Hi
Don't forget that you can get deep and shallow hole saws. And no I don't use the spring steel things. I have used the wooden plug method and that works well too.
David2452
6 Jun 2001
London & Fambridge
Hi
Yes, but how do you get two on a normal arbor? the thread and pegs hardly (if at all) protrude through the first one and leave no room for another. I know some arbors accommodate smaller saws up to about 25mm with a smaller thread but that would restrict the size of the smaller saw.
prv
29 Nov 2009
Southampton
Must depend on the arbour. Mine has more than enough thread to accept a second saw, and the pegs are just about long enough to engage.
I've not used it like that, though, was just fiddling about.
knuterikt
11 Sep 2006
Oslo, Norway
I have used wooden peg several times.
One easy way to make a peg is use hole saw with inner diameter matching the old hole and cut a disc out of a 2 inch plank.
This give you peg with perfectly centered hole.
If you don't have a hole saw with matching ID you can go down a little bit and just increase the diameter of the peg with gaffer tape.
Using gaffer tape on the center bit will work nice for smaller holes.
David2452
6 Jun 2001
London & Fambridge
I guess it must be then Pete, mine are all Starret arbors and saws apart from the Bosch power change cobalt ones which are completely different, on that note I noticed Starret are now offering a similar system to the Bosch one.
GrahamM376
30 Oct 2010
Swing mooring Faro
I used an angle grinder on end rather than plugging and hole saw for one of ours. Having replaced 6 of ours this winter I found if you can't get a spanner on the nut to undo the existing, then you may well need a deep box spanner to fit the new. Several of ours had a screw into the hull , hidden under antifoul, to stop them turning while the nut was fitted.
20 Feb 2014
Thank you for the Amazon link, just what I need have ordered a kit.
I presume using the peg in the hole is for enlarging existing holes if required, rather than a method for the removal of a jammed skin fitting itself.
David2452
6 Jun 2001
London & Fambridge
The plug is to centre the pilot then select a cutter of the same or slightly smaller size than the fitting shank, then cut off the flange and remove the fitting.
Sailfree
18 Jan 2003
Nazare Portugal
Was that the previous owner or a particular make of boat please?
Can't access my boat this weekend but trying the undo route first aided with plusgas, second undo nut enough to get in a metal cutting blade on a multi tool, Third (or poss earlier to se how easy) use a cone cutter up to 48mm and lastly try an angle grinder carefully on outside flange
knuterikt
11 Sep 2006
Oslo, Norway
Works for both..
A HSS Hole saw with same OD as the skin fitting centered with a wood peg give a nice smooth cut.
I prefer that method to using an angle grinder :)
