Removing green from spray hood
dnickj
6 Feb 2004
London
Another vote for patio magic - I just spray it on and leave it - the green has gone by the following week - it's best done when dry tho
Seven Spades
30 Aug 2003
Surrey
I have Boracol which I use on the deck, I didn't know if it would damage the fabric. I think patio magic is the same stuff as Boracol.
ronsurf
17 Jan 2007
Plymouth, D-heaven
Patio Magic - you can get it from Wilkinsons. I had to scrub my boom cover with a brush, then left it and it washes off. I guess you'd be wise to waterproof it afterwards, so it won't go green so quick. Suspect that it went green because it's not waterproof any more....
Seven Spades
30 Aug 2003
Surrey
You might be correct it is about three years old so it is probably about that time. What do you recommend for waterproofing?
VicS
13 Jul 2002
Patio Magic, apply with brush and leave for a week, any residue left can then be removed by washing with weak detergent solution..
Boracol :) its simple it works
Patio magic contains benzalkonium chloride
Boracol also contains disodium octaborate and ethane diol ( aka ethylene glycol)
Benzalkonium chloride is commonly used as an algaecide and fungicide
Disodium octaborate is also an insecticide and commonly used as a wood preservative.
Ethanediol aids penetration into wood
Unless the spray hood is suffering from wood worm I think Id stick to patio magic or one of the common domestic mould killers that are based on benzalkonium chloride. (Polycell 3 in 1 for example, which before someone finds a old msds or bottle no longer contains disodium octaborate)
jac
10 Sep 2001
Home Berkshire, Boat Hamble
+ 1 for patio magic. spray liberally. Leave for a week. Job done.
As for waterproofing - various off the shelf products are available - none that I can recommend - anything that anyone can recommend that are a simple spray on and leave solution - rather than something that involves removing cover or anything extreme like that.
Vara
20 Feb 2004
Canterbury/Dover
For proofing I use Fabsil, the basic one, I tried the expensive Fabsil gold, but despite its claims it didn't seem to offer any advantage.
If applying to newly washed fabric, ensure all traces of detergent are rinsed out of the material.
Using Patio Magic it does not seem to affect any water proofing in place.
