Removing Foam from an Engine Box
Sam_Steele
22 Apr 2003
Winchfield, Hampshire
www.circumnavigation-uki.co.uk
I am replacing engine noise insulation with some new fire resistance insulation and so I set about ripping out the old foam. That was the fun bit...now I am left with a thin layer of foam stuck to the inside of the wooden engine box. I have tried removing it..
Using a knife - still leaves a residual amount which I can sand off - but takes ages
Using a sharp scrapper....very slow and not much good.
Any other ideas that would remove it quicker
qsiv
30 Sep 2002
Channel Islands
You culd experiment with your 'offcuts' and see if you can find a suitable solvent - but beware of fumes and any action on fibreglass...
Anchorite
22 Oct 2002
FRANCE nr. Lyons
Re: I don\'t want to set the world on fire
And under the residual foam lies the real fun - the glue. If what's left now is anywhere near an even surface I'd leave it in place and put the new stuff over it.
if its foam. its polyuerophane based and theres almost nothing to disolve it without going over to chemical war.
its a good a base as any to glue on once the powdery stuff is sanded away
consider it a primer
Avocet
3 Jun 2001
Cumbria
I've had some limited success with a small hand held curved surform. It's like a baby cheese grater and the holes are so coarse it's very difficult to clog them. It might leave a few gouges in your wood but it might just even things up enough for you stick the new sheets over it.
longmoor
2 May 2003
PORTSMOUTH/GOSPORT
I recently replaced the foam on our Sigma with a modern fire resistant laminate. I agree with Anchorite, rough it down and then glue on the new stuff. If you really want to use a solvent then try acetone but use all sensible protective/safety measures.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by longmoor on 02/05/2003 22:42 (server time).</FONT></P>
