geem
I need to fit an inner forestay to my boat to fly a storm jib. The main forestay is 12mm. Conventional wisdom says drop one size for the removable inner forestay. Having a 10mm inner forestay tied back to the mast when not in use would be a pain. 10mm s/s is so stiff I am thinking of using 8mm instead as it should be less unwieldy. My storm jib is 150 sqft. Would 8mm s/s wire be up to the job on this size storm jib? I plan to install it about a foot back from the existing forestay so it wont see any rig load but it will see the load imposed by the sail area in storm force winds (but I hope not)
