Remove Black Stains from Deck/Old Rope Stains
MAGTRAD
Active Member
13 Apr 2021
I've got quite a few old back stains on my GRP deck along with stains left by old ropes. Does anyone know of any "magic" solutions to remove these or is it good old fashioned elbow grease?
So far used normal deck cleaner, traffic film remover and normal detergent to no avail.
My boat is a Moody 346 if it helps......looking forward to your replies!
Oxalic acid is pretty good.
Mix a near saturated solution, then add wallpaper paste and stir. When it just starts forming a gel, add a squirt of washing up liquid to "fix" the mixture.
Unfortunately, nor will the GRP if there are any voids in the gelcoat, and you won't know if there are until the pressure washer finds them.
Never had any problems on my Moody 31, and I've used a pressure washer many times. Nothing else will clean the diamond pattern non-slip effectively.
I haven't encountered the problem of voids, but surely if they exist it's better to know about them and fix them?
Really? You can usually spot a power washed Moody deck from a distance. The moulded non skid tends to get the very tops of the moulded bits blown off. It manifests itself as black bits on the deck. You can assume it's ingrained dirt in the valleys of the non skid but often (not always) it's dirt accumulated in the blown off peaks of the non skid. Suds and a soft brush will remove most build up, except leaf stains which tend to be particularly stubborn if they have been there for a while.
As I say, it's dirt in the valleys between the peaks that is hard to remove. A brush won't usually touch it, and the difference in colour between a deck that has been brushed and the same deck that has been power-washed is obvious and striking.
The fact that one deck moulding survives repeated pressure washing doesn't mean every deck will. Also a lot depends on the power and how close you use the jet. Personally I will not let a pressure washer on my deck - seen too much damage done on other people's boats. Two apparently identical Moodys (or any other make) could have very different deck moulding quality depending on how thick the gelcoat is and how well the first layer of glass is incorporated when being made.
Starbrite Non-Skid Deck Cleaner is your friend for that kind of thing :)
I am amused that a non-skid deck cleaner should contain PTFE. I should like to think that it washes off.
There are several kinds of black stain. I rather imagine that the OP's problem is similar to the grey streaking down some boats' topsides, for which there are proprietary cleaners with names like grey streak cleaner or removal. It would be worth trying one of these, or a non-specific detergent cleaner such as gelcoat cleaner from various companies. Oxalic acid as mentioned might work. It could also be mould, in which Patio Magic would be the answer. If the stain is very old it could be very hard to remove. For a gloss area it might be necessary to use an abrasive cleaner. I think the gentlest of these would be Starbrite's Color (sic) Restorer Polish, which I find very effective for tired areas.
