Removal of Transom Lettering
martin
Herts
Hi
After a few years off, I recently dived back into the boating world and am now the proud owner of a 2009 princess 50. This will be boat number 10 for me and hopefully, I will keep her for many years to come.
This time around I have decided to do more jobs myself as I can not say I have been impressed with any of the marine services companies I have used in this country over the years..Don't get me started !!
SO. The first job is to remove the old name and replace it with the new one. She currently has the usual plastic stickers which I plan on replacing with stainless steel lettering.
Has anyone got any tips on removing the old name ?
oldgit
6 Nov 2001
Medway
After warming and with careful use of stanley knife blade to lift corners of lettering (keep flat to avoid scratching gel coat) to start peeling off process, use paint thinners to clean off adhesive.
That adhesive is pretty amazing stuff, still spotting bits of sticky goo from Essex Boatyards for sale stickers after 5 years.
henryf
31 May 2007
Uxbridge
www.911virgin.com
To save damage I would suggest you don't use a Stanley knife blade. Just pick the corner of the letters with your finger nail.
Similarly I would avoid the use of a hot air gun. These are designed to heat paint until it burns and you can scrape it off. Use a hair dryer. These are specifically designed not to burn whilst still heating.
There is specific glue and tar remover available which doesn't evaporate like acetone etc. If you happen to be anywhere near Uxbridge I can let you have some as a new boat present.
Otherwise the general gist of the advice is correct.
Fine choice of boat by the way. Clearly a man of considerable taste. ;)
Henry :)
martin
Herts
Why.. Thank You All and espesh Henryf, I couldn't agree more...
I will launch first attack with Hairdryer and finger nails and see how I get on ... Will hopefully be in St Katharine Docks by Friday. If anyone around, please feel free to stop by and say Hi
I will be the one with the sore and no doubt blooded fingers :)..no job ever gets done on a boat without a cut, bruise or blood sacrifice of some sorts..
dingdongs
22 Feb 2010
st lawrence bay /essex
removal of name ceremony and renaming ceremony with a good bottle of champagne to keep the gods happy and your boat safe on the seas just to finish off.
Lovely boat and hope many years of enjoyment follow.
jimmy_the_builder
7 Sep 2005
Sussex
Congrats Martin, very nice boat. You'll be needing a new cardigan :D
On the name removal front, when I got my T40, she was four years old and the garage door (where the previous vinyl name lettering had been installed) had weathered slightly around the lettering - so even with the old lettering completely removed, you could still see the old name because the gelcoat where the old lettering had been was slightly shinier than the rest of the garage door. Only solution was to compound the whole area back before applying the new name. Worked perfectly.
rafiki_
19 Jan 2009
Stratford on Avon
As others have said, the lettering will come away surprisingly easily using a hairdryer. No bloodied fingers on this one, as the lettering will lift up without much force. As Jimmy says, compound the area, and stick yer new stainless letters on. We did this on Rafiki last year, and they look great imo.
A gift to the sea gods is appropriate, and I dont mean spanners or screwdrivers, as they have enough of mine, but a glug of something light and sparkly ususally works :)
jimmy_the_builder
7 Sep 2005
Sussex
Don't worry Jimmy I have the med move planned for a few years time and will be leaving the cardigan crowd and joining the budgie smuggler boys :)
Come on down! :D
