sailingrbg
I have after what I consider a great achievement been able to remove my two blade folding prop from my sail drive( first time). After removing the two allen screws on the propellor and knocking out both the large securing pins I am now having trouble removing the Sail Drive hub can some of the more learned gentleman please advise if this should pull straight off ?
i) is the purpose of the hub to transfer the rotaion from the gear box shaft onto the propeller?,
ii)is there any moving parts within the hub?
iii)I assume that forward or reverse gear does not need to be engaged to remove the hub?)
I have managed to get the hub to move slightly and have applied some penetrating oil but it does not want to budge even with a little heat from a hot air gun, perhaps I need a "puller"?
can anyone advise where to purchase one and roughly how much it would cost?
Any advise on how to get the hub off.
Also i assume that when it is removed should underwater grease be applied to the internal part of the hub any suggestions
Additionally can anyone advise where I could get a handbook on the volvo sail drive S110
Sorry for so many question but still in the learning process. Any help greatlfully recieved
