mjcp
Hi all,
Yet another thread about wiring of Nav lights / Anchor lights / steaming etc.
Leaving aside the pros and cons of Pulpit vs Mast top etc, I *WOULD* like to fit an anchor light to the top of the mast - I have an AquaSignal 40 tricolour up there currently. The plan is to replace with an LED Tri + Anchor in one unit.
(the current mast wiring is old and not tinned, so that's to be replaced, LED will allow for lower x-section thus cheaper wiring to be used)
I would *ALSO* like to keep my existing BEP switch panel intact, avoiding having to add additional switches to reverse polarity, select different lights. etc e.g. NASA Combi or shared wires e.g. Osculati tricolour / Anchor.
My BEP switch panel has 3 available single throw switches, currently: Navigation (pulpit and stern), "Mast light" and Steaming. (I'm unsure what the mast light switch is currently wired to, there is a separate switch for the fore deck working light, so not that!)
Digging through historic posts, there is discussion about switching, and there's mention of relays too, but nowhere can I find a wiring diagram.
An elegant solution would be keep the current switches, do some behind the scenes logic and drive the relevant lights for Anchor, sail and motoring from the three switches.
Any help appreciated.
Old post:
Switching between masthead and steaming lights
Old post:
