dip_lug
A 19 foot ketch, built in 1979, Northern Star, is a replica of the 1850s No Man’s Land Boats, use of the eastern United States. But after almost 25 years I’ve decided to replace the dip lug sails with Gaff or Gunter sails.
Lug sails have several inherent problems. The obvious, is the routine of dipping on each tack. They are inefficient to windward when compared to other sails. They do not hold a shape when reefed. In heavy weather, the yard often becomes a dangerous un-tethered missile when sail is raised or lowered.
Present configuration.
Main mast is forward enough to be a Cat boat. Mizzen is approximately three feet aft of centre line. Present sail configuration produces a heavy weather helm on a reach when under full sail. With only the mizzen set and tiller tied off, the boat will heave-to when driven into the wind. Both lug sails are free footed.
Proposed configuration.
Main and mizzen masts, gaff or a gunter with boom.
Addition of a bowsprit in order to add a foresail(s).
My thoughts on the configurations.
Sails
As per the original boats, Northern Star has relatively low masts; Main - 18 foot; Mizzen 14 foot. A gaff would have a low peak and the boom must be high enough to clear unwary heads. Both these factors would require small main and mizzen sails. By its design a gunter would have a higher peak eliminating one of two factors of the smaller gaff sail. However I know nothing about the gunter’s performance.
Bowsprit
I’ve been unable to find out any information as they apply to smaller boats, or the pros and cons of adding a foresail
I don’t want to take on this refit going at it completely blind relying on the trial and error method. It could be frustrating and expensive!
Your ideas or suggestions would be very appreciated.
Cheers, Colin.
Sails
Bowsprit
Cheers, Colin.
