rib
I thought it was clear.. The wind to push a tight roll as apposed to a loose roll which encourages jams... Any way I'm sure op has enough to play with for now and will find away. Good nightYour post#13 says the opposite "wind pushing the furl/sail tight" which is why I queried it!. Seems you were not explaining what you do clearly enough. The Selden advice is to have the wind off the starboard bow because the slot is profiled for the sail to furl in from the port side. The sheet should not be hard in so that there is any wind in the sail because as they suggest this puts load on the gears and make it hard work.
