ltcom
So they need to be on a gimble to remain vertical?
A further use was prompted from an AGM I attended yesterday. A commercial vessel captain had enquired of our secretary how he might identify the one boat out of a large cluster when communicating by radio (not DSC). He asked that some visual signal as a response.
Our secretary has installed a flashing orange beacon on his masthead switched on when in communication with the captain. (I believe that to be illegal.)
Using said red-over-greens could also be used.
A tricolour is required under Colregs:
No it is not.
Whenever this particular poster makes a direct factual assertion, it's a pretty good bet that the opposite is true
No it is not.
So the other posters (may:ambivalenceneed to offer you an apology--- this time at least:encouragement:
He could've rigged up multi-coloured lights driven off the audio channel. I'm sure some former wannabe DJ could've sold him the kit quite cheaply.Our secretary has installed a flashing orange beacon on his masthead switched on when in communication with the captain. (I believe that to be illegal.)
>No it is not.
Since Colregs specifically says a tricolour is required why did you say that?
>No it is not.
Just because someone is a Capt. Doesn’t mean they actually know what they are talking about
If in any doubt pick any thread on gcaptain. They come up with just as many weird and wonderful opinions as we do here.
I would suggest a reasonable bright flashlight with a Morse function. Pointed and flashed in the general direction of the vessel. Works quite well.
No Morse button. Cover with hand and uncover.
If you want to impress. With pukka signals.
Flash a series of double A’s (.-.- .-.- .-.-) A being .-
If he is polite he will reply with a long T -
Then call on VHF.
If you want to send K9 which means go to VHF.
And you will both know which boat is talking to the other.
>IWhere in Colregs does it specifically say you need a tricolour ? It doesn't.
You obviously didn't read the post properly have another look.
