SteveGroves
I,ve a 1990 Princess 435 with TAMD61 engines, there are two red lights installed on the dash (not on the Volvo instrument panels) these lights normally extinguish a couple of seconds after the ignition switch is turned to the first 'ON' position. However, The starboard engine light no longer goes off, even after the engine has started. I assumed they were diesel heater element indicators, which went off when the element came on, and the red light indicated a faulty element, but I,ve measured voltages across the element and get 13.8 volts, I,ve also changed the relay and checked voltages from the alternator etc but everything seems ok, and the engines and systems all seem to operate properly. Any idea,s from the forum would be greatly appreciated.
