sailorman
I don’t understand why the Belgians have to be blamed for a situation in UK;
Belgium was the last country in mainland Europe (I believe in 2006) that forbid the use of red diesel for leisure boating.
The first year after introduction of this law, there have been a few controll campaigns from customs.
The last two years I have not heard of ANY fines for using red diesel, nor any controls from customs.
On a Belgium boat forum, nobody could tell me of a recent case of customs control nor a fine.
Would be interested if somebody on here could tell us a real case.
I’ve seen a cominiqué from Dhr. Cockuyt, Gewestelijk Directeur van Douane en Accijnzen, dd 10 june 2010, that a more “reasonable” policy will be used against red diesel usage, knowing the problem of boaters sailing from UK in to Belgium.
Apart from that, I don’t see the problem, when you come to Belgium, boat partially filled with red Diesel, you go to a Belgium harbour, and fill up with white diesel, cheaper then your red (even at 60/40).
Refueling you have to do anyway in most cases.
Keep the receipt and you'r save.
I do appreciate the reason for red Diesel in UK, (as explained in post #38 by NickH), but do realize that this is a UK only regulation and exception with benefit for UK boaters.
Belgium has adapted to Europe regulations just as all other mainland Europe country’s. If there is someone to blame then it is your government who chooses to handle different rules then other Europe country’s.
Ones again; white diesel in marina’s in Belgium is cheaper then your marine red at 60/40 split (at least it was in September 2010 and September 2011)
]Apart from that, I don’t see the problem, when you come to Belgium, boat partially filled with red Diesel, you go to a Belgium harbour, and fill up with white diesel, cheaper then your red (even at 60/40).
Refueling you have to do anyway In most cases.
in many cases we come over for a w/e, little time to visit Niewpoort or Blankengerge as the destination is Oostende & the bright lights
