Recommendations for sail laundry Portsmouth
There used to be a place called Tip Top Sails IIRC.
Personally, it's a diy job.
Find a clean area of decking or patio. Or one you can clean!
Or lay out a bit of tarp or thick polythene?
In Gosport there is a launderette with industrial size machines that does it a for a few bob, and takes about 90 minutes.
Next to Dominoes Pizza, near the Memorial Hospital and Firestation on Bury Rd
It depends whether you want your sails chucked in a machine and beaten to death.
I think someone was advertising a process which unrolled the sails through a few troughs of stuff without creasing them?
Obviously new racing sails will need different treatment to soft old cruiser sails.
Any tips where to take my sails (only about 7sqm and 3 sqm) and rough cost to expect?
Almost any sail-maker will take them in send them to a laundry but they might expect to inspect and repair at the same time.
Some chandlers too. Arthurs Chandlery in Gosport have been mentioned in the past IIRC
Tip Top , mentioned above, don't take sails from Joe Public but take them via "Trade Partners " ie sail makers and chandlers, including Arthurs Chandlery. They use traditional methods I believe. Trade partners listed on the website
NovoSail ( Southampton) take sails directly and use modern hi-tech methods.
http://www.tiptopsails.com/
http://www.novosail.com/index-en.php
This Washeteria in Avenue Road ?? http://goo.gl/maps/5ydh on the corner with Privet Road
OK I suppose if you dont mind your sails being washed in a washing machine :(
Why do your sails need cleaning? A little used clean pontoon, fresh water and a deck brush is the cheapest and possibly the easiest method. A washing machine will knock the filler out of the sails which means that they won't catch as much wind.
+1, some fresh water and a brush is all that should be used, to get the cutting salt crystals off.
The thought of using a washing machine makes my toes curl.
+1 for Arun sails & replaced the window on my spray hood
We took a genoa there a few years back for a new UV strip. They insisted on sending the sail off to the laundry too.
We though they were a tad expensive but since we had not shopped around we just had to pay what they asked.
