Stooriefit
A couple of years ago I stripped two thirds of the hull using a scrapper. The remaining third was okay then but is now showing lots of crazing and is needing stripped back. Anyone able to recommend a chemical stripper?
The one on the right doesn't seem to feature the word "marine", which bodes well for the cost! Actually it seems to have a remarkably "Lidl-like" appearanceOwatrol "Marinestrip" or "Dilunett"
View attachment 128655 View attachment 128656 as Vyv' s suggestion or DIY version as savageseadog suggests
As far as one can tell from the safety data they are the same, at least contain the same concentration of caustic soda.The one on the right doesn't seem to feature the word "marine", which bodes well for the cost! Actually it seems to have a remarkably "Lidl-like" appearance![]()
Same here. It worked as well if not better than the commercial mixes. Anything will do to thicken it. It gets quite warm when you mix it up. The trick seems to be to leave it long enough to soften but not so long that it dries out. Certainly better than dry scraping.Caustic Soda solution with wallpaper paste. Needs to be a strong solution, I forget what strength I used but possibly about 200g/l. Take great care when using it!
And skin, given half a chance.it dissolves hair really well !!
Caustic soda combines with fat to make soap. That's why it dissolves fingers!And skin, given half a chance.
I used cellulose gun wash thinners and lots of rags and black rubbish bags.A couple of years ago I stripped two thirds of the hull using a scrapper. The remaining third was okay then but is now showing lots of crazing and is needing stripped back. Anyone able to recommend a chemical stripper?
Probably not if you have a two pack coating on there.On same subject would this stuff strip back to the metal on my keel.?
No thats the plan to strip back to the metal and prob VC tar.Probably not if you have a two pack coating on there.
