V1701
Yes I would like a Vapalux one day. Interesting what you say about the Trangia as the Origo Heat pal is VERY expensive (£140) for what it is (a burner in a heat shield) I wondered if you could buy a Trangia burner or even an Origo one and stick it in a biscuit tin or just have it open.
I have a Trangia burner which is spare as I have it linked up to a little gas bottle (much easier/quicker to use!) so I might try that - should have done it in the first place and saved a load of moneyI have probably just bought the equivalent of another Trangia by buying the Heatpal - idiot and could have used the money to buy a Vapalux or oil lamp....groan!
But the Origo is safe if kicked over & heats for 4/5 hours on a fill where the trangia lasts an hour if you're lucky then you have to wait for it to cool before you refill & relight. I think the Origo is about 1.5kw on full, I've read/seen somewhere that the Vapalux puts out about 1kw. I think for what you get for £50 a used Vapalux is good value for heat & light...
