essexsj
Hi all,
Currently looking at the possibility of relocating, and have been checking our marinas in new areas, I see that some have T&Cs which I find myself pondering over far too much.
Having only had experience within a boatyard where there are not any particular T&Cs other than to pay the pontoon berthing fees, or the hardstanding fees and lift-out etc., I'm wondering what the effect in real terms the following clauses have over doing your own 'boat work':
11. Subject to 12 no work shall be done to the Vessel whilst at the Company’s Marina or premises (unless with prior written consent of the Company which may be withheld at its sole discretion) other than minor running repairs or minor maintenance of a routine nature by the Owner, or Owner’s Party on a non paying basis not causing any nuisance or annoyance to any other users of the Company’s Marina or premises or any other person residing in the vicinity.
12. Prior written consent may be given or withheld at the Company’s sole discretion for work to be carried out on the Company’s Marina or premises – but will generally be given in the following circumstances:
٠ Where the work to be carried out is work which the Company decides, and states in writing that it cannot by itself or by the use of sub-contractors carry out.
٠ Where the Company is satisfied that the whole of the work is remedial and not servicing and is being carried out under warranty by the manufacturer and/or supplier of the Vessel or any part of her equipment to which the warranty relates.
Over the last couple of seasons, some instances of work I've done myself - I'm trying to find out how others deal with this if stated in your Marina 'contract T&Cs', or whether it is deemed as 'minor running repairs' or 'minor maintenance of a routine nature by the owner' or whether prior written consent/discretion etc is required:
Best regards, Steve.
- Install electric anchor windlass - power tool cutting and sanding of GRP and backing boards
- Power wash, scrape and re-paint antifouling to hull
- Clean and polish propeller and propshaft
- Add vinyl boat name decals
- Polish topsides of hull
- Remove and replace seacocks
- Winterise and servicing of engine
- Climb the mast to replace light bulbs and repair Windex
- Sanding and re-varnishing of interior woodwork
- Replace engine mounts
- Removed stern gland stuffing box and install PSS
