James W
In my eagerness to sort out the wiring on the boat, the cabin is currently like spaghetti junction, except with cable ties, bits of wire and rusty chocolate box connectors. I've now learnt that like most things on a boat, if you don't want to be presented with a huge and expensive task, don't scratch the surface. In fact, if it aint broke, then step softly away!
Anyway, the problem I have is that on the starboard side is the original wiring which is beautiful and neatly run dual core, but it looks like it's been done with domestic cable and is probably due for a change. On the port side is a whole mish-mash of new single core, as messy as hell and wrapped in insulation tape.
Despite it's age (circa 1970's) the starboard side cabling all still works and runs the Nav lights, whilst the port cables carry the cabin lights, VHF and masthead light.
I'm definitely going to replace the single core but do you think it's best done with dual core or single core all together in some sort of trunking? I like the neat run of the dual core but is it too much? Also, whilst i'm at it, should I replace the original dual core or leave it until it gives up?
Does 1.5mm cable seem like a good all round size to minimise voltage drop for cabin lights? I was thinking of using 2.5mm for the masthead light.
And can anyone recommend a quality connector please? I want to keep the joins down to an absolute minimum but i'm sure they'll have to be the odd one.
Thanks as always!
James
Thanks as always!
James
