James W
I've just finished an electrical refit on a 90 footer, 240ac, 12vdc & 12vdc, new everything including circuit breaker panels, consumer units, bus bars, sub panels, the lot, the largest one I've ever done and to be honest it's been a bit of a challenge (160m of AC cable alone), for what it's worth I'd use tinned single core except for long runs where the feed panel and return bus are close like mast nav lights and the like, single cable (ultra low voltage at any rate) is better than twin if not bundled too tightly as it has lower losses than tightly bundled stuff. Tinned copper un insulated terminals with separate covers are a good way to go as they make a good "ass cheek" roll over form which is very strong, avoid those red, blue, yellow auto crimps like the plague. I rarely do a schematic but always do a routing description, I identify the cables with printed heat shrink tube describing the function rather than using numbers and a separate chart now. try where possible to plan the job well before even starting, heavier single cable runs to smaller sub panels where possible saves time and is often easier for routing, work out the total load on the panel for the feed cable, not just for now but possible future additions where appropriate. Whether or not to start from scratch is a decision only you can make based on what you can see before you, but a blank canvas will give you a result you know will last if you are unsure about the state of the current install. Use the best quality consumables and crimping tool(s) you can afford. There is some good quality British made thin wall tinned cable around that is fairly reasonable if bought in bulk, you can always use it all with a bit of overkill on some circuits. A simpler and more accurate way to work out cable sizes which avoids the confusion of whether the table being used is based on round trip or simple distance from battery is 10.75 which is the constant assuming copper, times load amps, times round trip in feet, divide by the required volt drop (in volts) this gives the circular mil area which is easily convertible to AWG or mm2.
Thanks David, that's definitely helped a lot. I haven't decided quite what to do yet but you've certainly set me on the right path.
Much appreciated!
